Flow Interface Configuration Specification Editor Flow Interface Specs Tab
Use the Flow Interface Specs tab to select, add, and remove the Flow Interface specifications that use this Flow Interface Configuration specification. A Flow Interface specification can be associated with only one Flow Interface Configuration specification, but a Flow Interface Configuration specification can be associated with multiple Flow Interface specifications.
You must use this tab to relate a Flow Interface specification to its Flow Interface Configuration specification only when the Flow Interface specification and Flow Interface Configuration specification are in separate cartridges and the Flow Interface specification can exist without the Flow Interface Configuration specification.
If both the Flow Interface specification and Flow Interface Configuration specification are in the same cartridge, make the association from the Flow Interface specification.
| Field | Use |
Flow Interface Configuration |
Displays the name of the Flow Interface specification. |
Cartridge |
Displays the name of the cartridge project into which the Flow Interface specification is built. |
Select |
Click to select an existing Flow Interface specification. |
Open |
Click to open the selected specification in the Flow Interface Specification editor. |
Remove |
Click to remove a Flow Interface specification. |
Add |
Click to add a new Flow Interface specification. |
