Inventory Entity Editor
You use the Inventory Entity editor to review the inventory entities included in the ora_uim_model project. The editor displays the default data elements defined for the entity and (when applicable) the base entity from which the entity inherits data elements. This editor is read-only and is for informational purposes only.
