Overriding Default Values of Characteristics in Entity Specifications
You can override the default values of characteristics when you add them to entity specifications and entity configuration specifications. Additionally, you can override the values defined for drop down lists. This capability enables you to adjust values to meet specific circumstances without having to create new characteristic specifications.
When overriding characteristic default values, see the following topics:
