Pipe Configuration Specification Editor Pipe Specs Tab
Use the Pipe Specs tab to select, add, and remove the Pipe specifications that use the Pipe Configuration specifications. This tab identifies the Pipe specifications that use the selected Pipe Configuration specification. You must use this tab to relate a Pipe specification to its Pipe Configuration specification only when the Pipe specification and Pipe Configuration specification need to be in separate cartridges, and the Pipe specification can exist without the Pipe Configuration specification. If both the Pipe specification and Pipe Configuration specification are in the same cartridge, make the association on the Pipe specification.
| Field | Use |
Pipe Specification |
Displays the name of the Pipe specification. |
Cartridge |
Displays the name of the cartridge project into which the Pipe specification is built. |
Select |
Click to select an existing Pipe specification. |
Open |
Click to open the selected specification in the Pipe Specification editor. |
Remove |
Click to remove a Pipe specification. |
Add |
Click to add a new Pipe specification. |
