About Equipment Specification Ports, Connectors, and Equipment Holders
You can configure an Equipment specification so that instances of the specification automatically include physical ports, physical connectors, and equipment holders. If you include Physical Port, Physical Connector, or Equipment Holder specifications in the Related Specifications tab of an Equipment specification, instances of the ports, connectors, or holders are created automatically when you create instances of the equipment.
See "Defining Specification Relationships" for instructions about adding related specifications.
When you include a physical port or physical connector in an Equipment specification, you should set the minimum and maximum quantities to the same value. Ports and connectors are fixed parts of equipment.
