About Physical Device Specification Ports and Connectors
In Design Studio, you can include Physical Port and Physical Connector specifications in the Related Specifications tab of a Physical Device specification. When you create the physical device in UIM, instances of the ports and connectors are created automatically. The minimum quantity that you set governs the number of ports and connectors that are automatically added. The maximum quantity limits the number of ports and connectors that can be added. The minimum and maximum values are typically the same for ports or connectors of a physical device. See "Defining Specification Relationships" for instructions about adding related specifications.
When you include a physical port or physical connector in a Physical Device specification, you should set the minimum and maximum quantities to the same value. Ports and connectors are fixed parts of a physical device.
