Specification Editor Media Tab
Use the Media tab to add a media file, such as a JPG or GIF file, to a specification. When adding media files, you can specify the media type to determine the orientation of the image and how the image is used in the application.
For example, a media file of type front is used to display an entity as a node in a network visualization, as a node in a service topology visualization, and as an equipment (if the equipment is of the type CARD) in an equipment visualization. A media type of right would indicated that the image be used when the right side of the object is displayed. A media of type icon is used when displaying the equipment in a tree view.
UIM uses the media types front and icon only.
Field | Use |
Media Type |
Click to select how the media is to be used in the application. Select:
Media File |
Displays the path of the media file, such as JPG or GIF, which you have added to the specification. |
Remove |
Click to remove a media file. |
Add |
Click to add a new media file. |
Related Topics
