Working with Place Configuration Specifications
Place Configuration specifications capture the details about the resources used by the Place specification. Place configurations only apply to Place entities defined as sites.
You can add existing Place Configuration specifications to a Place specification or you can create new Place Configuration specifications in the process of adding it to a Place specification. The place configuration and the Place specification do not have to be in the same project.
When working with Place Configuration specifications, see "Place Configuration Specification Editor" for more information.
