Inventory Unit of Measure Properties Tab
Use the Properties tab to model the units used to measure capacity in UIM.
Field | Use |
Name |
Enter the name of the unit. |
Display Unit Value |
Enter the text to be displayed in menus and lists for this unit of measure. This is usually a shortened version of the name. |
Type of Measurement |
Specify the measurement type to which this unit of measure belongs. You specify this property by selecting or creating a measurement type. |
Conversion Description |
Enter a description of the conversion required to convert this unit of measure to the base unit of measure. |
Conversion Factor |
A multiplier used to convert a unit of measure to another unit of measure. For example, for a Mbps unit of measure, you could enter 1000000 as the conversion factor to bps. Note: Use a conversion factor that converts to the same base unit of measure for all units of measure for any given measurement type. |
Description |
Enter a description of this unit of measure. |
