17 Working with Media Stream Specifications
You use Media Stream specifications to model content such as audio or video media delivered over cable, satellite, radio, or streaming IP. Media Stream specifications represent provisional or subscription video services such as tiered services and a la carte packages.
When you define Media Stream specifications, you can add characteristics to supplement the default data elements.
You create Media Stream specifications in the same manner as you create other types of specifications. See "Creating New Specifications" for more information.
When working with Media Stream specifications, see "Media Stream Specification Editor" for reference information about the tabs you use to define a Media Stream specification.
