16 Working with Network Address Domain Specifications
In Oracle Communications Unified Inventory Management (UIM) network address domains define a context for the uniqueness of network addresses. For example, you can use network address domain to define private routing domains for IP addresses.
In UIM, you can use network address domains with the following entities:
Flow identifiers
IP subnets
Telephone numbers
Network Address Domain entities are based on specifications that you define in Design Studio. When you define a Network Address Domain specification, you define which entity type it covers. Predefined specifications are included in some reference cartridges. For example, the Carrier Ethernet cartridge includes a specification for VLAN domains.
When working with Network Address Domain specifications, see the following topics:
