Configuring an Entity-to-Data-Element Mapping
The types of mapping between entities and data elements are:
Value transformation mapping
Advanced mapping
To configure an entity-to-data-element value transformation mapping:
Open a mapping rule and click the Mapping tab.
In the Entries table, select the mapping you would like to configure.
In the Mapping subtab, click the target of the mapping you would like to configure.
In the Mapping Rule Item area, select Value Map.
In the Configuration subtab, Transform Value Selection area, click Add.
In the Output Value field, enter a value and click OK.
Configure the information in the Details, Condition, and Actions subtabs as necessary.
To configure an entity-to-data-element advanced mapping:
In the Mapping Rule Item area, select Advanced.
In the Mapping Rule Item area, enter information about the XQuery expression you would like to use. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. See "About Entity-to-Data-Element Advanced Mapping XQuery Expressions" for more information about this XQuery field.
Related Topics
