Creating New Mapping Rules
Mapping rules define the entity and data element mappings between two entities that have a named relationship.
To create new mapping rules:
From the Studio menu, select New, then select Order and Service Management, then select Order Transformation, and then select Mapping Rule.
The Mapping Rule wizard is displayed.
In the Project Name field, select the project in which to save the mapping rule.
In the Name field, enter a name for the mapping rule.
The name must be unique among mapping rule entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the mapping rule.
Oracle Communications Design Studio uses the last saved namespace as the default.
(Optional) Select a location for the mapping rule.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new Mapping Rule entity to the selected project and opens the new entity in the Mapping Rule editor.
Configure the properties for the mapping in the Properties tab.
Related Topics
