Creating New Order Item Fulfillment State Composition Rule Sets
You create new order item fulfillment state composition rule sets in Oracle Communications Design Studio to define a composite fulfillment state based on the fulfillment states of lower-level order items.
To create new order item fulfillment state composition rule sets:
From the Studio menu, select New, select Order and Service Management, select Orchestration, then select Order Item Fulfillment State Composition Rule Set.
The Order Item Fulfillment State Composition Rule Set wizard is displayed.
In the Project field, select the project in which to save the composition rule set.
In the Name field, enter a name for the composition rule set.
The name must be unique among order item fulfillment state composition rule set entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the composition rule set.
Design Studio uses the last saved namespace as the default.
(Optional) Select a location for the composition rule set.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new composition rule set to the Studio Projects view and opens the new entity in the Order Item Fulfillment State Composition Rule Set editor.
