Viewing Orchestration Fulfillment Pattern Dependencies
You can view the dependencies for orchestration fulfillment patterns using the Fulfillment Pattern Relation Graph Dependencies tab.
The Fulfillment Pattern Relation Graph Dependencies tab shows dependencies that exist between fulfillment functions within an orchestration fulfillment pattern and between orchestration fulfillment patterns. It shows a design-time perspective of the dependencies in the same way as the Dependency Graph region in the Orchestration Plan tab in the Order Management web client shows a run-time representation of the dependencies. This tab shows a graphical representation of the dependencies between functions at design time. You can view the dependencies between functions at design time and compare that against dependencies between functions at run time. The Fulfillment Pattern Relation Graph Dependencies tab shows a flow-based view; a relationship-based view is shown by the Fulfillment Pattern Relation Graph General tab.
To view the orchestration fulfillment pattern dependencies:
In Design Studio, open the Orchestration Fulfillment Pattern editor for the fulfillment pattern you are interested in.
Select the Orchestration Plan tab.
Open the Relation Graph view unless it is already open.
Select the Dependencies tab in the Relation Graph view.
Related Topics
