Order Item Fulfillment State Rule Information Subtab
Use the Rule Information subtab to capture additional information about the rule.
Field | Use |
Information |
Enter any additional information about the composition rule that is required by your specific situation. If you are localizing OSM, use the list to the right of the field to set different values for different locales. |
Related Topics
