Orchestration Product Specification Editor
Use the Orchestration Product Specification editor to edit OSM orchestration product specification configurations. You can add product specification inheritance, map the orchestration product specification to a fulfillment pattern, and describe the orchestration product specification characteristics.
Field | Use |
Description |
Edit the display name of the orchestration product specification. |
Namespace |
Select any existing namespace defined in the workspace, or enter a unique namespace in which to include the orchestration product specification. Design Studio uses the last saved namespace as the default value. |
Extends |
(Optional) Select an existing orchestration product specification to leverage the data and extend the functionality of that existing orchestration product specification. Do one of the following. Click:
Fulfillment Pattern |
Select an orchestration fulfillment pattern to which the corresponding orchestration product specification maps. An orchestration product specification must map to a single orchestration fulfillment pattern. Do one of the following. Click:
Effective Start Dates and Effective End Dates |
Select Immediately if you want the orchestration product specification to be in effect immediately. Otherwise, select the date at which the orchestration product specification becomes effective. Select No End Date to indicate that the orchestration product specification will remain effective indefinitely. Otherwise, select the date at which the orchestration product specification will no longer be used. |
Attributes |
Edit, remove, or create new orchestration product specification attributes. |
Related Topics
