About Recognition Rule XQuery Expressions
This topic describes how to use the Order Recognition Rule editor Recognition Rule area XQuery tab to write an expression that specifies a customer order and associates it with an OSM target order type. The XQuery has the following characteristics:
Context: The input document for the Recognition Rule XQuery is the customer order. For more information about typical customer order structures, see OSM Modeling Guide.
Prolog: You can declare the namespace for the customer order if you want to use the contents of the order as part of the recognition rule or you can omit the declaration if you only want to check the incoming customer order namespace. For example:
declare namespace im="http://xmlns.oracle.com/InputMessage";
Body: You must match the namespace you want to select for order processing with the namespace of the incoming customer order. For example, the following expression retrieves the namespace URI from the incoming customer order (fn:namespace-uri(.)) and compares it with this URI: 'http://xmlns.oracle.com/InputMessage':
fn:namespace-uri(.) = 'http://xmlns.oracle.com/InputMessage'
If you have declared a namespace in the prolog, you can also check to see if specific values exist in the order. For example, you can use the fn:exists function to check that an element exists. Or you can use a comparison expression such as = (equal to) or != (not equal to) to compare a value in the customer order with a value in the XQuery.
Tip:
Recognition rules are global entities within OSM, meaning that they can apply to any CreateOrder operation. Configure the relevancy settings and the recognition rule carefully to avoid having an incoming customer order recognized by a recognition rule that you do not intend. For more information about relevancy, see OSM Modeling Guide.
For example, in a simple scenario, the XQuery is based on a namespace:
The input message XML file includes the following line, which matches the namespace specified in the recognition rule:
<im:order xmlns:im="http://xmlns.oracle.com/InputMessage"
The XQuery expression returns a Boolean expression, for example, fn:true()
or fn:false()
The following example searches in a specific type of order:
fn:namespace-uri(.) = 'http://xmlns.oracle.com/communications/sce/dictionary/CentralOMManagedServices-Orchestration/CustomerSalesOrder'
In a more complicated scenario, you might create an XQuery expression that looks for a specific namespace and also interrogates the data within the incoming customer order. The following example shows a recognition rule that recognizes an order based on the following criteria:
Namespace
Value of the typeCode data element in the incoming customer order. In this case, the value must be OSM-BDB. This indicates an OSM business-to-business order.
The value of the FulfillmentModeCode data element in the incoming customer order. In this case, the value can be DELIVER, CANCEL, or TSQ.
declare namespace provord=";http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/ProvisioningOrder/V1";; declare namespace corecom=";http://xmlns.oracle.com/EnterpriseObjects/Core/Common/V2";; fn:namespace-uri(.) = 'http://xmlns.oracle.com/EnterpriseObjects/Core/EBO/ProvisioningOrder/V1' and fn:exists(../provord:ProcessProvisioningOrderEBM/provord:DataArea/provord:ProcessProvisioningOrder/corecom:Identification/corecom:BusinessComponentID) and ../provord:ProcessProvisioningOrderEBM/provord:DataArea/provord:ProcessProvisioningOrder/provord:TypeCode/text() = 'OSM-BDB' and ( ../provord:ProcessProvisioningOrderEBM/provord:DataArea/provord:ProcessProvisioningOrder/provord:FulfillmentModeCode/text() = 'DELIVER' or ../provord:ProcessProvisioningOrderEBM/provord:DataArea/provord:ProcessProvisioningOrder/provord:FulfillmentModeCode/text() = 'CANCEL' or ../provord:ProcessProvisioningOrderEBM/provord:DataArea/provord:ProcessProvisioningOrder/provord:FulfillmentModeCode/text() = 'TSQ' )
For more information about order recognition rules see OSM Modeling Guide.
