Transformed Order Item Fulfillment State Transformed Order Items Subtab
Use the Transformed Order Items subtab to specify the criteria that must be met for the selected condition to be evaluated. If no condition is selected, these fields are disabled.
Field | Use |
Order Item |
Click Select to select the order item specification that contains the transformed order items. |
Order Components |
This field enables you to constrain the order components for which this condition is applied. If order components are defined here, the condition will be applied only for those order components. If no order component is defined, the rule will be applied for all order components. Do any of the following:
Relationship |
This field enables you to determine whether the condition is applied based on the relationship between the original and transformed order items. If no relationship is configured, the condition will be applied regardless of the relationship. This list works in conjunction with the Order Item Relationship Exists check box. Do any of the following:
Order Item Relationship Exists |
Select this check box to indicate that one of the relationship types in the Relationship field must be defined between the original and transformed order items in order for the condition to be evaluated. Deselect this check box to indicate that the condition should be evaluated only if none of the relationship types defined in the Relationship field is defined between the original and transformed order items. |
Related Topics
Transformed Order Item Fulfillment State Rule Details Subtab
