Adding an Existing Data Structure Definition to an Order
You can add an existing data structure definition to an order.
To add a data structure definition to an order:
                     From the Studio menu, select Show Design Perspective.
                     Click the Studio Projects tab.
                     Double-click the existing order to which you want to add a data structure definition. The Order editor opens with the Order Template tab active. See "Order Editor Order Template Tab" for more information.
                     In the Order editor Order Template tab, right-click on the data element, select Select Data Structure Definition.
                     In Matching items, select a data structure definition.
                     Click OK. The data structure definition is added to the order, and all child data elements and structures of the data structure definition are also added and displayed. Note: Derived data structure definitions are not displayed in the order template.
                     Click Save.
