Event Behavior Properties View Event Tab
On the Properties view Event tab, you can specify how the OSM server should re-render an Task web client view when an event behavior occurs.
| Field | Use |
Save |
Select to signal the OSM server to re-render the Task web client view only after the user clicks the Task web client Save button. |
Refresh |
Select to signal the OSM server to re-render the Task web client view immediately after the user moves out of the field associated with the behavior. |
