Lookup Behavior Properties View Value/Name Tab
Use the Lookup Behavior Properties View Value/Name tab to specify the value that the OSM server should use for a data node, and to create multiple columns to display in the web client.
You can convert a label to a value by selecting the Set as Value check box. When you do this, the previous value automatically becomes a label.
| Field | Use |
Set as Value |
If you have multiple columns defined in the Value Name table, select the column whose value you want the OSM server to use for the data node, and click Set as Value. This value will be stored in the order. For example, if you have two columns, a code column and description column, you might elect to have the user make a selection based on the description field, but identify the code column as the value that the OSM server should use to update the task. Only one column in a lookup behavior can be used for Set as Value. Use the Hidden field to determine whether the column used as Set as Value is also used as a display column. |
Name |
Enter a name for the lookup value result. |
Hidden |
Specify whether the column is displayed or not. By default, the column is displayed. If more than one column is displayed, the value displayed in the field will be the value in the first visible column. |
Position |
Define the column's position in the lookup result. |
Sort Direction |
Specify how the column is sorted. Indicate either Ascending or Descending. |
Sort Order |
Determine how the column is used to sort the lookup. For example, if this value is 1, it is the primary sort key. |
Selection Severity |
Select how open the field is to users entering data that is not on the list of values defined in the lookup. Valid values are:
Node |
(Mandatory) Enter an XPath expression to define the relative path to the node in the nodeset. |
Language |
Select the display language. |
Description |
Enter a brief description of the layout. |
