Style Behavior Properties View Appearance Tab
Use the Properties view Appearance tab to define attributes that control the appearance of a given node in the web client.
The Appearance tab is rendered differently based on whether the behavior is defined for an element or a structure. For an element, all fields are enabled except Locate in, which deals with page layouts for structures. For a structure, all fields are disabled except Locate in.
Field | Use |
Appearance |
Select a value to control the appearance of the node based on one of the following selections:
Locate in |
Specifies the page on which the group is placed. New Page locates the group in a newly created page, without a title. |
Place on New Line |
Select to place the node at the start of a new line and to define a condition under which the line break is inserted. |
Make it a Password Field |
Select to protect the contents of nodes containing sensitive information and to define a condition under which the field is secret. |
