Adding New Data to an Order
You can create new data in the Data Dictionary and add it to the order.
To create new data:
  1. From the Studio menu, select Show Design Perspective.
  2. Click the Studio Projects tab.
  3. Double-click an existing order.
    The Order editor opens with the Order Template tab active. See "Order Editor Order Template Tab" for more information.
  4. Right-click inside the Order editor Order Template tab and select Open Data Element view.
    The Data Element view opens.
  5. Right-click inside the Data Element view and select Add Simple Schema Element or Add Structured Schema Element.
    The Create Data Schema Element dialog box or the Create Data Schema Structure dialog box is displayed.
  6. Complete the form and click Finish.
  7. Drag the new data from the Data Element view into the Order editor Order Template tab.
    Tip:
    Press and hold the Shift key to select multiple consecutive elements. Press and hold the Control key to select multiple non-consecutive elements.
Related Topics
Order Editor
