Creating the OracleComms_OSM_CommonDataDictionary Model Project
When you open or create an orchestration entity, Design Studio prompts you to create the data schema of the OracleComms_OSM_CommonDataDictionary model project in your workspace.
If you choose not to create the data schema in your workspace, dismiss the prompt and select the Do not show this prompt in the future check box. When you are ready to create the data schema in your workspace at a later time, see "Defining OSM Preferences" for information on re-enabling the prompt.
