About Contributing Task Data to a Cartridge Project
You may want to contribute task data to a cartridge project without directly modifying the modeled data within it. For example, you cannot directly modify the modeled data in a sealed cartridge project, but you may want to add task data to the existing tasks within it. You can contribute task data to a cartridge project without directly modifying it by including it as a component cartridge within a composite cartridge project. See "Working with Composite Cartridge Projects" for more information.
