Internal Custom Java Automator
A basic internal custom Java automator has the following characteristics:
The name of the custom automation package. For example:
package com.mslv.oms.sample.atm_frame;
Import statements required for this custom automation plug-in. For example:
import com.mslv.oms.automation.plugin.*; import com.mslv.oms.automation.*; import java.rmi.*;
An arbitrary class name that extends AbstractAutomator. For the automation framework to call an internal custom Java automator, the plug-in must extend the AbstractAutomator class. This class resides in the com.mslv.automation.plugin package. For example:
public class MyPlugin extends AbstractAutomator { -
The required run method, as dictated by the parent class, AbstractAutomator
protected void run(String inputXML, AutomationContext context) throws com.mslv.oms.automation.AutomationException { -
Cast the AutomationContext object to the TaskContext object. This example assumes that the custom automation plug-in is triggered by an automated task, so the code is expecting the context input an argument to be an instance of the TaskContext object.
TaskContext taskContext = (TaskContext)context;
You can use the TaskContext object to do many things, such as complete the task, suspend it, and so on. For more information about this class, see the OSM Javadocs.
Call a method on the TaskContext object to retrieve the task name.
String taskName = taskContext.getTaskMnemonic();
Add any require business logic.
this.performAutomation(taskname);
The following example shows the minimal amount of code required for a custom automation plug-in to run. This example assumes that it is triggered by an automated task.
import java.rmi.*;
try {
catch(RemoteException ex) {
throw new AutomationException(ex); }
catch(AutomationException x) {
throw x; }
