Event Automators
An event automation plug-in can be triggered when an order or a task transitions into a defined milestone. The automation can be any internal XQuery, XSLT, or custom automation since the milestone event, by definition, can only be triggered by milestones happening within an order or a task. For more information about the characteristics for these automations, see "Automation Plug-in XQuery Examples," "Automation Plug-in XSLT Examples," and "Custom Java Automation Plug-ins."
For an event automation plug-in you must declare the OrderNotificationContext instead of TaskContext. For example:
declare namespace context = "java:com.mslv.oms.automation.OrderNotificationContext";
The following example is an internal sender automation plug-in that uses methods available to the OrderNotificationContext class to get milestone data from the order and sends an notification message to an external system. Because this sender does not expect a response message (a fire-and-forget message), you must use the OrderNotificationContext class ackNotificationOnExit method to clear the JMS correlation ID for the notification. Also, events do not transition tasks, so you must not specify completeTaskOnExit in a notification.
declare namespace saxon="http://saxon.sf.net/";
declare namespace xsl="http://www.w3.org/1999/XSL/Transform";
declare namespace log = "java:org.apache.commons.logging.Log";
declare namespace outboundMessage = "java:javax.jms.TextMessage";
declare namespace oms="urn:com:metasolv:oms:xmlapi:1";
declare namespace osm="http://xmlns.oracle.com/communications/ordermanagement/model";
declare variable $context external;
declare variable $log external;
declare variable $outboundMessage external;
let $taskData := fn:root(.)/oms:GetOrder.Response
let $correlationId := $taskData/oms:_root/oms:Id/text()
let $controlDataArea := if (fn:exists($taskData/oms:_root/oms:ControlData))
then $taskData/oms:_root/oms:ControlData
else ()
return
log:info($log, fn:concat('COMCartridge: Invoking orderCompletionNotification for order[',$taskData/oms:OrderID/text(),'] with correlation [', $correlationId,']')),
context:ackNotificationOnExit($context),
outboundMessage:setStringProperty($outboundMessage, "COMCorrelationID", $correlationId),
outboundMessage:setStringProperty($outboundMessage, "SUB_FOLDER_NAME", $taskData/oms:_root/oms:OrderNumber/text()),
outboundMessage:setStringProperty($outboundMessage, "COMMilestone", "COMOrderCompleteEvent"),
<orderNotification xmlns="http://xmlns.oracle.com/communications/sce/dictionary/CommonResourcesCartridge/Notifications"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<OSMOrderId>{$taskData/oms:OrderID/text()}</OSMOrderId>
<Id>{$correlationId}</Id>
<OrderNumber>{$taskData/oms:_root/oms:OrderNumber/text()}</OrderNumber>
for $serviceInstance in $controlDataArea/oms:OrderItem
return
<Instance>
<InstanceID>{$serviceInstance/oms:instanceID/text()}</InstanceID>
<OrderLineId>{$serviceInstance/oms:orderLineId/text()}</OrderLineId>
<Status>{$serviceInstance/oms:status/text()}</Status>
</Instance>
</orderNotification>
