Designing Timer Delays
By default, timer delays use the null_rule. To use OSM resources efficiently and minimize database table entries, Oracle recommends that you define a custom order rule and apply it to the timer delay. By applying an order rule to the timer delay, you avoid creating a separate automated task to evaluate the rule.
See "Defining Order Rules" and "Applying Order Rules to Timer Delays" for more information.
