Internal XQuery Automator
The Automated Task editor internal XQuery automator receives task data from OSM, then processes the data. For example, such an automation might perform computational actions on the data or other similar logic. This XQuery combines characteristics of external XQuery automators and internal XQuery senders. See "External XQuery Automator" and "Internal XQuery Sender" for more information.
You must declare ScriptReceiverContextInvocation class in an internal XQuery automator.
