Internal XSLT Automator
The Automated Task editor internal XSLT automator receives task data from OSM, then processes the data. For example, such an automation might perform computational actions on the data or other similar logic. This XSLT combines characteristics of external XSLT automators and internal XSLT senders. See "External XSLT Automator" and "Internal XSLT Sender" for more information.
You must declare ScriptReceiverContextInvocation class in an internal XSLT automator.
