Modifying Cartridges After Upgrading OSM Versions
If the OSM software is upgraded to a new version, all cartridges in use must be rebuilt using the updated SDK and redeployed. See the discussion on Upgrading OSM in OSM Installation Guide for details on upgrading cartridges when you upgrade to a new version of OSM.
