Defining Language Preferences
Design Studio for OSM supports multiple languages for fields in the Task web client or the Order Management web client (through the use of the Information behavior). Use the language preference settings to define the languages that you intend to use in your OSM cartridges, and the language with which you prefer to work. You define language preferences in the Oracle Design Studio Preferences dialog box.
To define OSM language preferences:
  1. From the Window menu, select Preferences.
    The Preferences dialog box is displayed.
  2. Select Oracle Design Studio.
  3. Click New.
    The Add Language dialog box is displayed.
  4. Select a language from the available options.
  5. Click OK.
    Design Studio adds the language to the Languages group.
  6. (Optional) Define the language display priority.
    When multiple languages appear in the Languages group, use the Up and Down buttons to reposition the language display priority. The language display priority controls the order in which the languages appear in Design Studio language drop-down lists.
  7. (Optional) Click Remove to delete a language from the Languages group.
  8. In Preferred Language, select the language from your language list in which you prefer to work.
  9. Click OK.
    Design Studio saves your language preferences and closes the Preferences dialog box.
If you deploy or import into OSM cartridges that support languages that you have not included in your language group, the system displays a warning message indicating that the language is not currently supported. To include that language in your language list, you can return to the Language Preferences page and add it. Also note that you must specify the English [en] language setting to use the OSM sample cartridges.
