Process Editor Start Properties General Tab
Use the Process Editor Start Properties General tab to define properties at the process level, including the expected duration of the process, the reference name, and whether it is a workstream process.
Field Use
Duration
Define the expected duration of the process in weeks, days, hours, minutes, and seconds.
Process History
Select True if you want this process to appear in the Process History - Summary Table window in the Task web client. If you do not want this process to appear in the Process History - Summary Table window in the Task web client, select False.
Reference
Displays the order with which this process is associated. To change the association, click the Select button to access a list of orders.
Workstream
Select True to define the process as a workstream process. See "Designing Workstream Processes" for more information.
X, Y coordinates
Indicates the present X and Y pixel coordinates for the Start entity.
