About Selection Controls
Use the following context menu options to control the Process editor selection features:
Field Use
Make Select Active
Select to enable the Selection tool.The Selection tool enables you to make an object active. You can also press the Esc key to activate the Selection tool when other tools in the Tool drawer are active.
Pan
Select to reposition the contents in the process editor. Click the Pan icon to make the tool active, then drag the graphic into the desired position. If the Selection tool is active, you can activate the Pan tool by pressing the Control key and clicking the left mouse button.
Note: The Pan tool remains active for a single use only. When you release the left mouse button, the Pan tool is deactivated and the Selection tool becomes active. If you want the Pan tool to remain active for multiple instances, activate the Sticky Mode tool.
