Subprocess Properties General Tab
You use the Subprocess Properties General tab to define general information about the subprocess, such as the description and display name.
| Field | Use |
| Description | Enter a description of a task to help differentiate between tasks used more than once in the same process flow. |
| Display Name | Enter the name that you want to appear in the subprocess task entity in the Process editor. |
| Process History | Select True if you want this task to appear in the Process History - Summary Table window in the Task web client. Otherwise, select False. |
| X, Y coordinates | Coordinates that indicate where in the Process editor the subprocess task exists. |
