Role Editor Role Tab
You use the Role editor to assign permissions to role entities. To access the Role editor, double-click any role entity in the Studio Projects view. The Role editor enables you to modify the name that displays for the role in the Task web client and to assign to the corresponding role any combination of the following permissions.
Field | Use |
Create Versioned Orders |
Enables users to create orders for different versions of cartridges. If not granted this permission, users can create orders only for the default version of the cartridge. |
Exception Processing |
Enables users to alter the flow of a process by applying exception statuses at any time throughout the process. |
Online Reports |
Enables users to view summarized reports on all orders and tasks on the system. |
Order Priority Modification |
Enables users to modify the priority of a task in an order. |
Reference Number Modification |
Enables users to modify the reference number of an order. |
Search View |
Enables users to access the order Query function. |
Task Assignment |
Enables users to assign tasks to others. |
Worklist Viewer |
Enables users to access the Worklist function. |
Related Topics
