Converting Tasks
Design Studio enables process modelers to create tasks in the absence of detailed design-level information. Consequently, as you model your tasks, you may need to convert the task from one type to a different type.
You can convert between manual, automated, activation, and transformation tasks.
Caution:
When converting from one type of task to another, Design Studio displays a prompt if the potential for data loss exists (for example, when converting from an automated task to a manual task). Consider your task conversions carefully before implementing them.
To convert a task to a different task type:
In the Process editor, right-click a task and select Convert.
Select the task type to which you want to convert.
