9 Importing product specifications
You can import product specification definitions from external catalogs compliant with a TMF 620 Product Catalog Management API. Doing this associates the product specification with a diagram.
To do this:
The product specification is now part of the initiative you specified
when importing and you can add it to a diagram that belongs to the same initiative. If
you specified a diagram when importing, the product specification appears in that
diagram.
