2 Solution Requirements
This chapter describes the requirements for deploying the Digital Business Experience Solution.
Prerequisites for Deploying the Solution Components
Refer to the Digital Business Experience Compatibility Matrix for information about the required solution components.
For information on the prerequisites for your deployment of the solution components, refer to the following:
Launch Overview, for Launch.
About Configuring and Deploying Your BRM Cloud Native Environment, for BRM.
The topic "Before You Begin", in the chapter Deploy Oracle Analytics Server on Oracle Cloud, for OAP.
Planning and Validating Your Cloud Native Environment, for OSM.
Generating the OSM Cloud Native Artifacts for the Order-to-Activate Solution, for O2A.
Requirements for Installing and Configuring Siebel CRM, for Siebel.
Preparing to Install and Configure Oracle Data Integrator, for ODI.
Prerequisites for Your AIA Cloud Native Deployment, for AIA.
