2 Solution Requirements
This chapter describes the requirements for deploying the Digital Business Experience Solution.
Prerequisites for Deploying the Solution Components
Refer to the Digital Business Experience Compatibility Matrix for information about the required solution components.
For information on the prerequisites for your deployment of the solution components, refer to the following:
- For Oracle Communications Launch Cloud Service: Launch Overview in Launch Cloud Service User's Guide
- For Oracle Communications Billing and Revenue Management Cloud Native: About Configuring and Deploying Your BRM Cloud Native Environment in BRM Cloud Native Installation Guide
- For Oracle Analytics Server (OAS): Before You Begin in Oracle Analytics Server Documentation
- For Oracle Communications Service Catalog and Design (SCD): Planning and Validating Your Cloud Environment in SCD Solution Designer Installation Guide
- For Oracle Communications Order and Service Management (OSM): Planning and Validating Your Cloud Native Environment in Cloud Native Deployment Guide
- For Oracle Communications Order-to-Activate (O2A): Generating the OSM Cloud Native Artifacts for the Order-to-Activate Solution in Order-to-Activate Solution Guide
- For Oracle Siebel CRM: Requirements for Installing and Configuring Siebel CRM in Siebel Installation Guide
- For Oracle Data Integrator (ODI): Preparing to Install and Configure Oracle Data Integrator in Oracle Data Integrator Installation Guide
- For Oracle Application Integration Architecture (AIA): Prerequisites for Your AIA Cloud Native Deployment in AIA Cloud Native Deployment Guide
