Grounding Guidelines
Use the following guidelines for grounding the server:
  • The rack must use grounding type power cords. For example, Oracle Communications Server E6-2L use three-wire, grounding-type power cords.
  • Always connect the grounding-type power cords to grounded power outlets.
  • Because different grounding methods are used, depending on location, verify the grounding type. For the correct grounding method, refer to local electrical codes.
  • Ensure that a facility administrator or qualified electrical engineer verifies the grounding method for the building and performs the grounding work.
