Installing the Operating System
Task Description Reference
1
Review the server Product Notes for information updates.
2
Install the server hardware and connect to the Oracle ILOM service processor.
3
Confirm the OS release you want to install.
Supported Operating Systems
4
Select an installation method:
  • Oracle Linux – Manual Installation or Automated Installation using Kickstart
  • VMware ESXi – Manual Installer or Automated Installer
5
Verify that your system meets the requirements for the operating system installation:
  • Minimum memory, disk space, and other system requirements.
  • Firmware is updated to the latest version.
6
Prepare to install the operating system.
Preparing to Install an Operating System
7
Install the operating system.
8
Reboot the server before using the operating system.
Powering the Host On and Off
9
Perform post-installation tasks.
Refer to the server Product Notes to review any issues or operating notes.
Oracle Linux
  • (Optional) Register with the Unbreakable Linux Network (ULN).
  • Obtain errata information and updates from the Oracle Linux yum server. Individual RPM packages for released versions of Oracle Linux as well as update/errata packages can be obtained from the Oracle Linux yum server.
