Modifying Network Settings
This section provides information about the default network settings on the service processor (SP), and procedures for viewing and modifying those settings in Oracle ILOM:
The servers support dual-stack IPv4 and IPv6 settings, which enable Oracle ILOM to fully operate in an IPv4 or IPv6 network environment.
- IPv4 configurations – DHCP is enabled by default, allowing a DCHP server on the network to automatically assign network settings to the service processor.
- IPv6 configurations – IPv6 stateless auto-configuration is enabled by default, allowing an IPv6 router on the network to assign the network settings.
In a typical configuration, you accept the default settings. However, if you want to modify the service processor network settings, use the following procedures.
