Oracle Hardware Management Pack
Oracle Hardware Management Pack provides command-line interface (CLI) tools for managing your servers, and an SNMP monitoring agent.
- Oracle Hardware Management Pack CLI
- Allows you to configure Oracle servers
- Works with supported operating systems
- You can script the tools to support multiple servers, if the servers are the same type
- Hardware Management Agent SNMP Plugins
- Allows you to use SNMP to monitor Oracle servers from the operating system using a single host IP address
- Connect to two management points (Oracle ILOM and the host) with only one connection
For more information, refer to product information. Refer to Oracle Hardware Management Pack Documentation at: Servers Documentation Systems Management
