BIOS Setup Utility Looks Distorted When Accessed Through Oracle ILOM Remote System Console
Bug ID 32035569
Issue: If you disable serial console redirection, and then launch the BIOS Setup Utility through the Oracle ILOM Remote System Console, the main screen of the BIOS Setup Utility is distorted upon first accessing the utility.
Workaround: From the main screen of the BIOS Setup Utility, click the Advanced tab, and then return to the Main tab. Returning to the main screen of the BIOS Setup Utility clears the distortion.
