Configuring RAID
The BIOS RAID configuration utilities support configuring RAID. You can configure RAID arrays using the BIOS RAID configuration Utilities.
Before you can install an operating system on a storage device:
The storage device must appear as a valid target to the OS installation program.
If you want a RAID array, configure the RAID volume before installing the OS.
Caution:
Configuring RAID removes the OS and all other data from the target drives.
Type of RAID:
Software RAID – The OS manages the array, which normally must be created and configured using an OS. In a typical use case, you boot an OS on one device to create a software RAID volume on a different device.
