PreviousNext
JavaScript must be enabled to correctly display this content
Restore a Saved Oracle ILOM Configuration (Oracle Hardware Management Pack)
Access the operating system command line with root privileges.
Type the ilomconfig import command:
ilomconfig import config
--xmlfile=filename.xml
To confirm that you want to proceed, at the confirmation prompt, type
y.
A second prompt appears asking whether you want to specify a
passphrase. If you used a passphrase to encrypt sensitive data in the backup file,
the passphrase is required to restore the sensitive data.
If you included sensitive data in the XML file, and you want to restore
the sensitive information, enter the passphrase.
For details, refer to Configuring Oracle ILOM (ilomconfig), Oracle Hardware Management Pack
Server CLI Tools User's Guide at Systems Management Documentation.
