Using Oracle ILOM
Oracle ILOM can be used to configure the system and to monitor the health of the system. It is firmware embedded on the service processor, and does not need to be installed. You can access Oracle ILOM any time the system is connected to power, whether the host is operational or not.
You can access Oracle ILOM locally or remotely using a web interface or a command-line interface (CLI). To get started, see the following sections:
