PreviousNext
JavaScript must be enabled to correctly display this content
View and Resolve Faults (Oracle Hardware Management Pack)
Access the operating system command line with root privileges.
Type hwmgmtcli list open_problems.
A list of faults diagnosed on the server appears. Each entry includes
a link to an Oracle Knowledge Article, which describes a corrective action.
=== open_problems report ===
Open Problem 1
Problem time : Thu Apr 1 22:38:19 2021
Problem subsystem : System
Problem location : /SYS (Host System)
Problem description : The top cover of server was opened while AC
input was still applied to the power supplies. (Probability: 100, UUID:
8bb87e70-d210-632b-d553-fc1450105bc4, Part Number: 31112054+1+1, Serial
Number: 1242FML0UV, Reference Document: http://www.sun.com/msg/SPX86-8003-8C).
Open Problem 2
Problem time : Fri Apr 2 10:37:48 2021
Problem subsystem : Storage
Problem location : /SYS/DBP0/HDD2
Problem description : The disk temperature has exceeded the critical
limit. (Probability: 100, UUID: N/A, Part Number: H106030SDSUN300G, Serial
Number: 001234NTR1KD PWGTR1KD, Reference Document: N/A)
